Wi-Fi Blackout
Wi-Fi Blackout lets you disable the Wi-Fi radio on a recurring timetable. During a blackout window, the radio is powered off entirely — all Wi-Fi devices disconnect regardless of their profile, while Ethernet-connected devices are unaffected.
Use Cases
- Limit late-night usage — Disable Wi-Fi from 10 PM to 7 AM so household members are not online at night.
- Reduce RF exposure — Power off the radio during sleeping hours to minimize radiofrequency EMF in the home.
- Energy savings — Turn off Wi-Fi when nobody is home during the day.
Note
Wi-Fi Blackout affects the radio hardware itself, not individual devices or profiles. When Wi-Fi is off, all Wi-Fi-connected devices are disconnected regardless of their profile. Ethernet-connected devices are unaffected. For per-profile time restrictions on Internet access (not Wi-Fi connectivity), use WAN Blackout in Security Profiles.
Setting a Schedule
The schedule is displayed as a 7-day visual timeline grid, with one row per day of the week. Blackout windows appear as shaded blocks on the timeline.
Navigate to
Points of Entry > Wi-Fi > Schedule. -
Click “Add” to create a blackout window.
Set the start and end times for the blackout period. Times use a 12-hour
HH:MM AM/PMformat, with a 15-minute quick-pick dropdown. A window may cross midnight (e.g. 10:00 PM to 6:00 AM). Setting the start time equal to the end time creates a full 24-hour window. -
Select which days of the week the window applies to.
Click “Save”.
Multiple blackout windows per day are supported. For example, you could disable Wi-Fi from 12:00 AM to 6:00 AM and again from 10:00 PM to 12:00 AM.
Overlapping windows are rejected when you save. A schedule that covers the entire week with no gap is also rejected — the system needs at least one boundary to toggle the radio on and off.
Tip
Click a window once to edit it.
Note
If the router reboots during a blackout window, the schedule is re-evaluated at boot and the radio is powered back off for the remainder of the window. There is a brief interval early in boot, before the controller starts, during which the radio may come up momentarily before the blackout is reasserted.
Removing a Schedule
To remove a blackout window, click it and click “Delete”. Removing all blackout windows effectively disables the schedule — Wi-Fi will remain on at all times.
