Keyboard shortcuts
Press ← or → to navigate between chapters
Press S or / to search in the book
Press ? to show this help
Press Esc to hide this help
start-cli Reference
The primary CLI for managing a StartOS server. Connect via SSH to run commands locally, or use --host to manage a server remotely. Pass -h at any level to see subcommands and options.
Service developers will find the S9PK Packaging and Registry sections especially useful. The tunnel subcommand group is documented separately in the StartTunnel CLI Reference.
Global Options
These apply to all subcommands.
  • -c, --config <PATH> — Configuration file path
  • -H, --host <URL> — StartOS server URL
  • -r, --registry <URL> — Registry URL
  • --registry-hostname <HOST> — Registry server hostname
  • --s9pk-s3base <URL> — Base URL for publishing s9pks
  • --s9pk-s3bucket <BUCKET> — S3 bucket for publishing
  • -t, --tunnel <URL> — Tunnel server address
  • -p, --proxy <URL> — HTTP/SOCKS proxy
  • --id-key-path <PATH> — Identity signing key path (--developer-key-path is accepted as an alias)
  • --id-key-gpg <KEY> — Sign through gpg-agent with this GnuPG key (fingerprint, key ID, or user ID) instead of the identity key file
Shell Completion
The Debian package and StartOS image enable Bash tab completion automatically in new shells. For other installations, add eval "$(start-cli completions bash)" to ~/.bashrc. start-cli completions <shell> also supports Zsh, fish, elvish, and PowerShell.
From the Browser Console
The same API is reachable from the StartOS web interface. While logged in, open your browser’s developer console and call a command through rpcClient.rpc, writing its path in camelCase and passing its arguments as an object:
await rpcClient.rpc.server.setHostname({ hostname: 'my-server' })
await rpcClient.rpc.package.start({ id: 'bitcoind' })
Authentication
Log in, log out, manage enrolled device keys and bearer tokens, and reset the master password.
start-cli auth login
Log in and enroll this device’s signing key. Required before running any commands against a remote server.
start-cli auth logout <SESSION>
Remove an enrolled device key.
start-cli auth reset-password
Reset the master password. Must be run locally (via SSH or physical access).
start-cli auth get-pubkey
Retrieve the server’s public key.
start-cli auth session list
List all enrolled device keys and bearer tokens.
  • --format — Output format
start-cli auth session kill [--pubkey <KEY>]... [--token <ID>]...
End one or more sessions. --pubkey removes an enrolled device key; --token revokes a bearer token by the ID auth session list shows.
start-cli auth token create --name <NAME>
Create a bearer token for an API client that cannot sign requests. The token is printed once and is not stored; the client sends it as Authorization: Bearer <token>. It appears in auth session list under its name and is revoked with auth session kill --token or after 30 days unused.
An MCP client authenticates with the same token to use the server’s API as tools at https://<server-address>/mcp, over the streamable HTTP transport.
Server
Restart, shut down, update, and configure the server.
start-cli server restart
Restart the server.
start-cli server shutdown
Shut down the server.
start-cli server update
Check the supplied registry for OS updates and apply if available. See Trusted Keys for signer requirements.
  • --trust — Explicitly accept an untrusted signer while retaining signature and integrity checks
start-cli server update-firmware
Update the server firmware.
start-cli server logs
Display StartOS system logs. These are also readable and downloadable in the web interface under System — see Logs.
  • -l, --limit <N> — Max entries
  • -f, --follow — Stream in real-time
  • -c, --cursor <POS> — Start from cursor
  • -B, --before — Show logs before cursor
  • -b, --boot <ID> — Filter by boot ID
start-cli server kernel-logs
Display kernel logs. Same options as server logs.
start-cli server metrics
Display server metrics: CPU, RAM, disk, and temperature in °C.
start-cli server time
Display server time and uptime.
start-cli server device-info
Display hardware and device information.
start-cli server rebuild
Tear down and rebuild all service containers.
start-cli server trust-ca --cert <PEM>
Add a PEM-encoded CA root to the StartOS host trust store. Pass the certificate text with --cert. Use shell substitution to read it from a file or standard input:
start-cli --host https://server.local server trust-ca --cert="$(cat company-root.crt)"
cat company-root.crt | start-cli --host https://server.local server trust-ca --cert="$(cat)"
The command requires authentication and reports the certificate subject and SHA-256 fingerprint. StartOS identifies the root by that fingerprint, so installing the same certificate again keeps a single copy. StartOS’s own HTTPS connections, such as registry, update, and package downloads, trust the root immediately, and it persists across reboots and OS updates. It is added alongside the StartOS local Root CA and the distribution trust bundle.
This command changes the host trust store. Services use the trust store provided by their package, so configure custom roots within a service separately when supported.
start-cli server set-hostname <HOSTNAME>
Set the server’s name, which is its .local address without the .local on the end.
start-cli server set-smtp
Configure SMTP for email notifications.
  • --host <HOST> — SMTP server hostname (required)
  • --port <PORT> — SMTP port (required)
  • --from <EMAIL> — Sender address (required)
  • --username <USER> — Auth username (required)
  • --password <PASS> — Auth password
  • --security <MODE> — starttls or tls (required)
start-cli server test-smtp
Send a test email to verify SMTP configuration.
  • --to <EMAIL> — Recipient address (required)
  • --password <PASS> — Auth password (required)
start-cli server clear-smtp
Remove SMTP configuration and credentials.
start-cli server set-language <LANGUAGE>
Set the system display language.
start-cli server set-keyboard <KEYBOARD>
Set the keyboard layout.
start-cli server set-echoip-urls [URLS...]
Set the Echo IP service URLs used for external IP detection.
start-cli server governor [SET]
View or set the CPU governor (e.g., performance, powersave).
start-cli server epp [SET]
View or set the CPU energy/performance preference. StartOS applies balance_power on Librem Mini v2 systems when no preference is saved and the setting is available.
start-cli server experimental zram
Enable or disable ZRAM compressed swap.
  • --enable — Enable zram
Server Host Management
Manage network addresses and bindings for the server UI host.
start-cli server host address list
List all addresses assigned to the server host.
start-cli server host address domain private add <FQDN> <GATEWAY>
Add a private domain to the server host.
start-cli server host address domain private remove <FQDN>
Remove a private domain from the server host.
start-cli server host address domain public add <FQDN> <GATEWAY> <INTERNAL_PORT>
Add a public domain to the server host.
  • --acme <PROVIDER> — ACME provider for certificate
start-cli server host address domain public remove <FQDN>
Remove a public domain from the server host.
start-cli server host binding list
List network bindings for the server host.
start-cli server host binding set-address-enabled <INTERNAL_PORT>
Enable or disable a specific address binding.
  • --address <ADDRESS> — Address to modify (required)
  • --enabled <true|false> — Enable or disable
Services
Install, start, stop, and manage service packages.
start-cli package list
List all installed packages.
start-cli package install [ID] [VERSION]
Install a package from the registry or sideload a local .s9pk file.
  • -s, --sideload — Install from local file
Registry installs and sideloads require a signer trusted for packages by default.
start-cli package start <ID>
Request that a service run. If active critical tasks block execution, the CLI warns and records running intent. The service starts automatically when its blocking tasks clear.
start-cli package stop <ID>
Stop a running service.
start-cli package restart <ID>
Restart a running service. If the service is still starting, StartOS lets startup complete, then stops and starts the service again. Repeated restart requests during the same startup coalesce into one additional restart.
start-cli package uninstall <ID>
Remove a package and its data. See Uninstalling.
  • --soft — Keep the package’s data
  • --force — Remove the package even when its own uninstall step fails or can’t run
start-cli package logs <ID>
Display logs from a service. These are also readable and downloadable on the service’s Logs tab in the web interface — see Logs.
start-cli package attach <ID> [-- COMMAND]
Open a shell inside a service’s subcontainer (within the LXC container), or run a one-off command. If the service has only one subcontainer, you are placed directly into it; if there are multiple, you will be prompted to choose. See Accessing Service Containers for details.
  • -n, --name <NAME> — Select the subcontainer by name; the package’s README lists them
  • -s, --subcontainer <GUID> — Select the subcontainer by its internal Guid, or a prefix of it (names go to -n)
  • -i, --image-id <ID> — Select the subcontainer by the image it runs
  • -u, --user <USER> — Run as this user instead of the image’s default
  • --force-tty — Force TTY mode
start-cli package stats
Display LXC container memory usage and limit for every installed service. It does not report CPU use.
start-cli package rebuild <ID>
Rebuild a service’s container.
start-cli package installed-version <ID>
Show the installed version of a package.
start-cli package cancel-install <ID>
Cancel a pending install or download.
start-cli package set-outbound-gateway <PACKAGE> [GATEWAY]
Override the outbound gateway for a specific service, taking precedence over the system-wide default.
start-cli package action run <PACKAGE_ID> <ACTION_ID> <INPUT>
Run a service action (e.g., show credentials, configure settings).
  • -p, --package-id <ID> — Package identifier
start-cli package action get-input <ACTION_ID>
Retrieve the input spec for a service action.
start-cli package action clear-task <PACKAGE_ID> <REPLAY_ID>
Clear a pending service task.
  • --force — Force clear even if running
start-cli package backup restore <TARGET_ID> <PASSWORD> [IDS...]
Restore one or more packages from a backup.
Service Host Management
Manage network addresses and bindings for a service host.
start-cli package host address list
List all addresses for a service host.
start-cli package host address domain private add <FQDN> <GATEWAY>
Add a private domain to a service host.
start-cli package host address domain private remove <FQDN>
Remove a private domain from a service host.
start-cli package host address domain public add <FQDN> <GATEWAY> <INTERNAL_PORT>
Add a public domain to a service host.
start-cli package host address domain public remove <FQDN>
Remove a public domain from a service host.
start-cli package host binding list
List network bindings for a service host.
start-cli package host binding set-address-enabled <INTERNAL_PORT>
Enable or disable a specific address binding for a service.
Backups
Create backups and manage backup targets (network shares).
start-cli backup create <TARGET_ID> <PASSWORD>
Create a backup of all or selected packages.
  • --old-password <PASS> — Previous backup password (for re-encryption)
  • --package-ids <IDS> — Limit to specific packages
start-cli backup target list
List configured backup targets.
start-cli backup target info <TARGET_ID> <SERVER_ID> <PASSWORD>
Display backup information for a target.
start-cli backup target mount <TARGET_ID> <PASSWORD>
Mount a backup target.
  • --server-id <ID> — Server identifier
  • --allow-partial — Leave media mounted even if backupfs fails
start-cli backup target umount [TARGET_ID]
Unmount a backup target.
start-cli backup target delete-legacy <TARGET_ID>
Delete this server’s legacy (V1) backup from a target. The backup is removed immediately; its space is reclaimed in the background, with a notification when it finishes.
start-cli backup target cifs add <HOSTNAME> <PATH> <USERNAME> [PASSWORD]
Add a new CIFS/SMB network share as a backup target.
start-cli backup target cifs update <ID> <HOSTNAME> <PATH> <USERNAME> [PASSWORD]
Update an existing CIFS backup target.
start-cli backup target cifs remove <ID>
Remove a CIFS backup target.
Networking
Manage gateways, DNS, ACME certificates, tunnels, port forwards, and SSL vhosts.
start-cli net gateway list
List all gateways.
start-cli net gateway set-name <GATEWAY> <NAME>
Rename a gateway.
start-cli net gateway set-default-outbound <GATEWAY>
Set the system-wide default outbound gateway, used by every service without its own override.
start-cli net gateway set-secure <GATEWAY> [SECURE]
Mark a gateway’s network as trusted, so services’ non-SSL addresses are offered on it. See Secure Gateways.
  • SECURE — true (the default) or false
start-cli net gateway unset-secure <GATEWAY>
Let StartOS decide whether a gateway’s network is trusted with unencrypted traffic — it trusts only the loopback and container-bridge gateways.
start-cli net gateway check-dns <GATEWAY>
Test DNS resolution through a gateway.
start-cli net gateway check-port <GATEWAY>
Test port connectivity through a gateway.
start-cli net gateway forget <GATEWAY>
Remove a gateway from the system.
start-cli net dns set-static [SERVERS...]
Set static DNS server addresses.
start-cli net dns query <FQDN>
Test DNS resolution for a domain.
start-cli net dns dump-table
Display the full DNS routing table.
start-cli net ssl generate-certificate <HOSTNAMES>...
Generate an SSL certificate signed by the system Root CA. The command outputs the private key and full certificate chain in PEM format.
  • HOSTNAMES — One or more hostnames or IP addresses to include in the certificate (required)
  • --ed25519 — Use Ed25519 instead of the default NIST P-256
start-cli net acme init
Initialize ACME (Let’s Encrypt) certificate provisioning.
  • --provider <PROVIDER> — ACME provider identifier or URL (required)
  • --contact <EMAIL> — Contact email for the certificate authority
start-cli net acme remove
Remove ACME certificate configuration.
  • --provider <PROVIDER> — ACME provider to remove (required)
start-cli net acme check-challenge <FQDN> <GATEWAY>
Test whether a certificate authority can reach the domain to validate it. An ACME authority connects on port 443 regardless of which port the address itself is served on, so this tests 443 — over IPv4, and over IPv6 where the gateway has a global address. Reports nothing when the domain needs no such test: it holds a certificate with life left in it. A domain with no ACME authority, or one already served on 443, has no question to ask here.
  • --acme <PROVIDER> — ACME provider identifier or URL (required)
start-cli net tunnel add <NAME> <CONFIG> [GATEWAY_TYPE]
Add a WireGuard tunnel gateway.
  • --set-as-default-outbound — Use this tunnel as the default outbound gateway
  • GATEWAY_TYPE — inbound-outbound or outbound-only
start-cli net tunnel remove <ID>
Remove a tunnel gateway.
start-cli net forward dump-table
Display the port forwarding table.
start-cli net vhost add-passthrough
Add an SSL passthrough vhost.
  • --hostname <HOST> — Hostname (required)
  • --listen-port <PORT> — Listen port (required)
  • --backend <ADDR> — Backend address (required)
  • --public-gateway <ID> — Public gateway
  • --private-ip <IP> — Private IP
start-cli net vhost remove-passthrough
Remove an SSL passthrough vhost.
start-cli net vhost list-passthrough
List SSL passthrough vhosts.
start-cli net vhost dump-table
Display the full vhost routing table.
SSH Keys
Manage authorized SSH keys for server access.
start-cli ssh add <KEY>
Add an SSH public key.
start-cli ssh list
List authorized SSH keys.
start-cli ssh remove <KEY>
Remove an SSH key.
WiFi
Connect to and manage wireless networks.
start-cli wifi add <SSID> <PASSWORD>
Save a WiFi network and its credentials.
start-cli wifi connect <SSID>
Connect to a saved WiFi network.
start-cli wifi remove <SSID>
Remove a saved WiFi network.
start-cli wifi get
Display the current WiFi connection.
start-cli wifi available
List available WiFi networks.
start-cli wifi available get <SSID>
Get details of a specific available network.
start-cli wifi country
Display the current WiFi country code.
start-cli wifi country set <COUNTRY>
Set the WiFi country code (ISO 3166-1 alpha-2).
start-cli wifi set-enabled
Enable or disable WiFi.
  • --enabled — Enable WiFi
Notifications
View and manage system notifications.
start-cli notification list [BEFORE] [LIMIT]
List notifications.
start-cli notification create <LEVEL> <TITLE> <MESSAGE>
Create a notification.
  • -p, --package <ID> — Associate with a package
start-cli notification mark-seen [IDS...]
Mark notifications as read.
start-cli notification mark-seen-before <BEFORE>
Mark all notifications before an ID as read.
start-cli notification mark-unseen [IDS...]
Mark notifications as unread.
start-cli notification remove [IDS...]
Delete notifications.
start-cli notification remove-before <BEFORE>
Delete all notifications before an ID.
Kiosk Mode
Control the local display.
start-cli kiosk enable
Enable kiosk mode on the connected display.
start-cli kiosk disable
Disable kiosk mode.
Disks
List, repair, and format storage devices.
start-cli disk list
List all disks and partitions. Unmountable partitions and EFI system partitions are omitted.
start-cli disk repair
Repair filesystem issues on the data partition.
start-cli disk format <DISK>
Erase a whole drive and leave it with a single Btrfs partition ready for backups, then print the new partition. The drive holding StartOS or its data, the live boot medium, anything mounted, and drives smaller than 1 GiB are refused.
  • --label <LABEL> — Volume label, at most 255 bytes (default StartOS Backups)
Diagnostics
Troubleshoot issues when the system is in diagnostic mode.
start-cli diagnostic logs
Display diagnostic logs. Same log options as server logs.
start-cli diagnostic kernel-logs
Display diagnostic kernel logs. Same log options as server logs.
start-cli diagnostic error
Display the current diagnostic error.
start-cli diagnostic restart
Restart the server from diagnostic mode.
start-cli diagnostic rebuild
Rebuild all containers from diagnostic mode.
start-cli diagnostic disk forget <GUID>
Forget a disk so the system no longer expects it.
start-cli diagnostic disk repair
Repair a disk from diagnostic mode.
Database
Low-level access to the system database.
start-cli db dump [-p <POINTER>] [PATH]
Dump database contents, optionally filtered by JSON pointer.
  • -p, --pointer <PTR> — JSON pointer to a specific value
start-cli db apply <EXPR> [PATH]
Apply a patch expression to the database.
start-cli db put [PATH] [VALUE]
Set a value in the database.
start-cli db put-ui [PATH] [VALUE]
Set a value in the UI database.
S9PK Packaging
Build, inspect, edit, and publish service packages.
start-cli s9pk init-workspace [PATH]
Initialize a StartOS packaging workspace in PATH (default: the current directory). Clones the monorepo’s live-docs branch — what every product has published — writes the agent-context files (AGENTS.md, AGENTS.local.md, CLAUDE.md), and creates a .startos/ directory holding the workspace signing key and host/registry config. Nesting is allowed; it refuses to run inside a package repo. See Set Up Your Packaging Workspace.
start-cli s9pk init-package <NAME>
Scaffold a new package from the current workspace’s template, using NAME (e.g. "Hello World") as the human-readable package name, then run npm install. Must be run inside a workspace.
start-cli s9pk pack [PATH]
Build an s9pk package from source files.
  • -o, --output <PATH> — Output file path
  • --javascript <PATH> — JavaScript bundle path
  • --icon <PATH> — Service icon path
  • --license <PATH> — License file path
  • --assets <PATH> — Assets directory path
  • --no-assets — Build without assets
  • --arch <ARCH> — Filter by CPU architecture
start-cli s9pk sign <S9PK>
Add a supplemental signature to a v2 package using the configured identity key (including a GPG-agent identity). The base archive and its embedded signature remain unchanged. Existing valid supplemental metadata and unknown fields are preserved; malformed or unsupported trailer versions are refused. Content-changing edits discard supplemental metadata with a warning, requiring the resulting package to be signed again.
start-cli s9pk publish <S9PK>
Publish an s9pk to the configured S3 bucket and index it on the registry.
start-cli s9pk convert <S9PK>
Convert an s9pk from v1 to v2 format.
start-cli s9pk select [S9PKS...]
Select the best compatible s9pk for the target device from a list.
start-cli s9pk list-ingredients [PATH]
List all file paths that would be included in a pack. Same options as s9pk pack.
start-cli s9pk inspect manifest
Display the package manifest.
start-cli s9pk inspect file-tree
Display the file tree inside the s9pk.
start-cli s9pk inspect cat <FILE_PATH>
Extract and display a file from the s9pk.
start-cli s9pk inspect commitment
Display the root sighash and max size.
start-cli s9pk edit manifest <EXPRESSION>
Apply a patch expression to the manifest.
start-cli s9pk edit add-image <ID>
Add a container image to the s9pk.
  • --docker-build — Build from Dockerfile
  • --dockerfile <PATH> — Dockerfile path
  • --workdir <PATH> — Build context directory
  • --docker-tag <TAG> — Docker image tag
  • --arch <ARCH> — CPU architecture filter
  • --emulate-missing-as <ARCH> — Emulate missing arch
  • --nvidia-container — Enable NVIDIA support
Registry
Manage a StartOS package registry — the server that hosts, indexes, and distributes s9pk packages and OS updates. These commands can be run remotely via start-cli registry, or locally on the registry server using the standalone start-registry binary (same subcommands, different entry point).
start-cli registry index
List registry metadata and all packages.
start-cli registry info
Display the registry name, icon, and description.
start-cli registry info set-name <NAME>
Set the registry’s display name.
start-cli registry info set-icon [ICON] [--clear]
Set the registry’s icon from a file path, an http(s) URL, or a data URL. Supply either ICON or --clear, but not both.
  • --clear — Remove the registry’s icon
Over RPC, pass null in the setter’s icon field to clear it; a value sets it.
start-cli registry info set-description [DESCRIPTION] [--clear]
Set the registry’s description (markdown), shown above its services in the marketplace. Supply either DESCRIPTION or --clear, but not both.
  • --clear — Remove the registry’s description
Over RPC, pass null in the setter’s description field to clear it; a value sets it.
start-cli registry info set-trust-signers [SIGNER...]
Select which existing signers the registry offers to StartOS servers for package trust. Run it without signer IDs to clear the selection. See Trusted Keys for how StartOS treats offered keys.
Registry Admin Management
Manage registry administrators and their signing keys.
start-cli registry admin add <SIGNER> [DATABASE]
Add a signer as an administrator.
start-cli registry admin remove <SIGNER>
Remove an administrator.
start-cli registry admin list
List all administrators.
start-cli registry admin signer add [DATABASE]
Register a new signer identity.
  • -n, --name <NAME> — Signer display name (required)
  • -c, --contact <INFO> — Contact information
  • --key <KEY> — Public key
start-cli registry admin signer edit <ID>
Edit a signer’s metadata.
  • -n, --set-name <NAME> — Update name
  • -c, --add-contact <INFO> — Add contact
  • -k, --add-key <KEY> — Add public key
  • -C, --remove-contact <INFO> — Remove contact
  • -K, --remove-key <KEY> — Remove public key
  • --remove-gpg-export <PRIMARY_FINGERPRINT> — Remove whole GPG exports containing this primary-key fingerprint, preserving signing keys (repeatable, case-insensitive)
start-cli registry admin signer list
List all registered signers.
Registry Package Management
Add, remove, index, and distribute service packages.
start-cli registry package index
List all packages and categories.
start-cli registry package add <FILE>
Add a package to the registry from a local s9pk file.
  • --url <URL> — URL of the package
  • --no-verify — Skip signature verification
start-cli registry package remove <ID> <VERSION>
Remove a package version from the registry.
  • --sighash <HASH> — Hash for signature verification
start-cli registry package get [ID] [OTHER_VERSIONS]
List installation candidates for a package.
  • -v, --target-version <RANGE> — Version range constraint
  • --source-version <VERSION> — Source version for upgrade path
  • OTHER_VERSIONS — Detail level: none, short, or full
start-cli registry package download <ID>
Download an s9pk package file.
  • -v, --target-version <RANGE> — Version constraint
  • -d, --dest <PATH> — Destination path
start-cli registry package add-mirror <FILE> <URL>
Add a download mirror for a package.
start-cli registry package remove-mirror <ID> <VERSION>
Remove a package mirror.
  • --url <URL> — Mirror URL to remove (required)
start-cli registry package sign [FILE]
Add your signature to a package in the registry index.
  • --no-verify — Sign the commitments the registry lists instead of a local s9pk
  • --id <ID> — Package identifier (with --no-verify)
  • --version <VERSION> — Package version (with --no-verify)
Registry Package Categories
Organize packages into browseable categories.
start-cli registry package category add <ID> <NAME>
Create a new category.
start-cli registry package category remove <ID>
Delete a category.
start-cli registry package category list
List all categories.
start-cli registry package category add-package <ID> <PACKAGE>
Add a package to a category.
start-cli registry package category remove-package <ID> <PACKAGE>
Remove a package from a category.
Registry Package Signers
Manage cryptographic signers authorized for packages.
start-cli registry package signer add <ID> <SIGNER>
Authorize a signer for a package.
  • --versions <RANGE> — Version range to authorize
  • --merge — Merge with existing range instead of replacing
start-cli registry package signer remove <ID> <SIGNER>
Revoke a signer for a package.
start-cli registry package signer list <ID>
List authorized signers for a package.
Registry OS Versions
Manage StartOS version records in the registry.
start-cli registry os index
List all OS versions.
start-cli registry os version add <VERSION> <HEADLINE> <RELEASE_NOTES> <SOURCE_VERSION>
Register a new OS version.
start-cli registry os version get
Get OS version information with filters.
  • --src <VERSION> — Source version to upgrade from
  • --target-version <VERSION> — Target version constraint
  • --id <SERVER_ID> — Server identifier
  • --platform <PLATFORM> — Target platform
start-cli registry os version remove <VERSION>
Remove an OS version.
start-cli registry os version signer add <VERSION> <SIGNER>
Add a signer for an OS version.
start-cli registry os version signer remove <VERSION> <SIGNER>
Remove a signer from an OS version.
start-cli registry os version signer list <VERSION>
List signers for an OS version.
Registry OS Assets
Upload and manage OS installation images (IMG, ISO, squashfs).
start-cli registry os asset add <FILE> <URL>
Upload an OS asset to the registry.
  • -p, --platform <PLATFORM> — Target platform (required)
  • -v, --version <VERSION> — OS version (required)
start-cli registry os asset sign <FILE>
Sign an OS asset and register the signature.
start-cli registry os asset remove img <VERSION> <PLATFORM>
Drop one platform’s IMG file from a version’s index entry. The asset bytes stay where they are; this removes the registry’s record of them, which is what frees the platform slot for a re-index.
start-cli registry os asset remove iso <VERSION> <PLATFORM>
Drop one platform’s ISO file from a version’s index entry. Same arguments as remove img.
start-cli registry os asset remove squashfs <VERSION> <PLATFORM>
Drop one platform’s squashfs file from a version’s index entry. Same arguments as remove img.
start-cli registry os asset get img <VERSION> <PLATFORM>
Download an IMG file.
  • -d, --download <DIR> — Download directory
  • -r, --reverify — Verify hash after download
start-cli registry os asset get iso <VERSION> <PLATFORM>
Download an ISO file. Same options as get img.
start-cli registry os asset get squashfs <VERSION> <PLATFORM>
Download a squashfs file. Same options as get img.
Registry Database
Low-level access to the registry database.
start-cli registry db dump [-p <POINTER>] [PATH]
start-cli registry db apply <EXPR> [PATH]
Initial Setup
Commands for the first-boot setup process.
start-cli setup disk
Configure the data disk during initial setup.
start-cli setup cifs
Configure a CIFS/SMB network share during initial setup.
start-cli setup logs
Display setup logs. Same log options as server logs.
start-cli init subscribe
Stream initialization progress events.
start-cli init logs
Display initialization logs. Same log options as server logs.
start-cli init kernel-logs
Display initialization kernel logs. Same log options as server logs.
start-cli init-key
Create a new developer signing key.
Utilities
start-cli echo <MESSAGE>
Echo a message back from the server. Useful for testing connectivity.
start-cli flash-os <SQUASHFS> <DISK>
Flash a StartOS image to a drive.
  • --efi <true|false> — Use EFI boot mode
start-cli git-info
Display the git hash of this build.
start-cli pubkey
Display the developer public key.
start-cli state
Display the current API specification.
start-cli util b3sum <FILE>
Calculate the BLAKE3 hash of a file.
  • --no-mmap — Disable memory-mapped I/O
